Advice/Questions new system
darron016
Got stock battery and alternator.
1300 watt amp wired to 2 ohms, so im guessing im not getting full RMS.
2 sa 12's, im going to big 3 upgrade when it gets warmer out.
Im going to add a 4channel amp, I want to place it in my trunk.
Will I need to get a battery in my trunk if I have 2 amps?
Also how much power do you think each SA is actually seeing?
1300RMS amp wired to 2 ohms, 4 gauge wire and still have my 80a maxi fuse.
too many variables.. maybe someone could give you a very rough estimate.. but we need to know voltage, specific amp, what cu ft box.. I think haha
what amp is it ? is it 1300@1 ohm ? or 1300 @2ohms ? yes u will need a extra battery along with a good agm under the hood
---------- Post added at 11:34 PM ---------- Previous post was at 11:33 PM ----------
yes gota be more specific if u want close to the right answer
darron016
darron016
minneapolis, mn
NASTY08IMPALA
