- Thread Starter
- #61
i set the crossover on my HU.. according to the manual after i set it to "on" i should pick up everything down to 20 Hz.. but im still not lol... is it possible to be sending too much power to the sub so that it doesnt pick up lows? idk?well, when i used to run my type r in a small pre fab box (1 cf) i used to get the same thing when listening to white girl. Once i put it in a bigger box it did better, also, you need to look in your manual how to adjust the lows and the EQ curves on you head unit. If you have the lows down it will decrease your 45 htz range alot. An i mean, ALOT. Don't freak out just yet?
And how much power are you feeding them? Find your manual to the head unit to.
and im using a hifonics 1208d wired at 2 ohms so it should be getting 900w assuming hifonics is rated correctly.. which i know it isnt but id say its getting for sure 700-800
edit: what does non-fader phase do: i can set it at normal or reverse.. HU manual doesnt explain exactly what that does
