adjusting crossover and eq on deck
newyorkjets00
was wondering if you could help me set my eq on and crossover on my head unit..
my dash speakers are infinity refrence 4x6's
doors are cheap jvc 6 1/2 for now
subs 2 10s dvc 2 ohms
sub amp
http://www.crutchfield.com/p_06719000XE/MA-Audio-M1900XE.html?tp=115
speaker amp
http://www.crutchfield.com/S-ZsdVScvCu7c/p_575G12004/Rockford-Fosgate-Punch-200-4.html?o=M&c=3
the subs are not hitting as hard as they were with my older kenwood i had on them not sure whats wrong there... and the door speakers you can barely hear.
im not use to the double din settings always had a single din here it is though thanks in advance.
http://www.crutchfield.com/S-mBOGiqyJwTf/App/Product/Item/Main.aspx?I=613DDX8017
its prob because the preout voltage is diff
if you set gains with a headunit that has a higher preout and then hook up a hu with low voltage u need to reset gains, use a 1khz tone for the speakers and a 50hz tone for the subs and use a dmm to set them
tryin to adjust the pq equalizer on the deck... bank 1,2,3 and 4 for the dash and doors in a truck. my dash speakers are bassing im scared there gona blow i just want highs coming from them...
look at the amp... turn up the highpass filter so no bass goes to the speakers lol. people are giving u help ur just not coming back to post what u have it set at ect
i have been pm that guy but he hasnt been on lately since i messed with it and there is only one switch to flip i tried it and didnt help.. the settings need to be fixed on my deck i took my 4ch out today and went back to my radio for the speakers.. i cant even hear the door speakers i dunno whats wrong with them?
I'm not familiar with the menu/screens on the 8017. Your front speaker amp crossover doesn't look adjustable, looks like its hard set at 120hz and up, that sucks.
That headunit should have the ability to crossover your front speaker amp at different frequencies...read the manual to find out how and start around 80hz and see if your speakers take it, if so go lower...with the 120hz filter on your speaker amp turned off.
You should have a low pass crossover in your deck for the subwoofer as well, just need to do some reading to figure out where to set it in the deck.
This deck has 5v preouts so guessing gains is not your issue...might want to see if your deck has a subwoofer level control and if so crank that up. I know my current kenwood has that and pretty sure my last kenwood screen had it.
umm the front is adjustable to whatever you want.. i have it at 250hz and 24db
and it has all the crossovers i just dont know what to set them at..
and where is this? is that like subwoofer level control
umm the front is adjustable to whatever you want.. i have it at 250hz and 24db and it has all the crossovers i just dont know what to set them at..
250hz? Tick Tick
newyorkjets00
newyorkjets00
Lake Whitney
newyorkjets00
