A Sub With No Sound
timebomb0220
im new to the whole audio thing but i followed instrutions and everything but my friend told me to do this one thing that isnt working. *all i want to power is a sub with my factory speakers.
i have a 1997 oldsmobile cutlass supreme
i bought a walmart special //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif i no i no
http://www.sonicelectronix.com/item_9833_TIS+Audio+T510PK.html
that what it looks like its called tis audio it have a 5 channel amp and a 10" sub i followed directions i ran the wire threw my car (the red wire) to my battery then the other wire (the blue wire) to the powered antena after that i tired to tapp into the back left speaker by spilting the low L and R on the back left speaker then on the amp i ran it LEft speaker L and R then i plugged the sub in. i turned on my system the amps getting power but the sub has nothing coming out of it. how can i make this subwoofer work.
You have NO idea WTF you are doing.
Sub connected ?
Do you seriously not see the problem here?
first of all i have no idea what you were trying to say. second you need someone who knows what they are doing to help you. and third did you run rca's to your amp?
hey idesignboxes do you actually want to help or be the forum ******* of the night?
first off, timebomb, do you have the stock HU or a new one installed? I would assume you have a stock hu because you want to run it off your current setup. They make adapters for your stock hu but i'm not knowing in that area. one thing you want to look at is what is your wire setup right now?
you should have:
power wire from battery
ground wire (grounded good on a frame bolt, i'm not so sure you want to ground that to the antenna)
remote wire (this turns the amp on and off with the head unit)
rca signal cables (this sends the music to your sub)
Ding, ding, ding, we have a winnar here!
ding ding ding your still wrong he obviously doenst have an aftermarket deck sooooo
by useing the speaker level inputs on an amp it could work but i have no idea what hes saying soooo
ding ding ding your still wrong he obviously doenst have an aftermarket deck soooooby useing the speaker level inputs on an amp it could work but i have no idea what hes saying soooo
Did he say he didn't have an aftermarket deck?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
OK everyone listen i have a stock H.U all i wanted was more bass i wanted a little rumble in my stock unit i finall figured out that i have the speakers going in a output so i cut sum rcs cables ran rca from the speakers lows Land R to the rcs input rear speaker then i did sub output and nwo it works but when i turn up the bas and stuf fon the amp nothing really happens my system in my car is better without the bass then with something depleating my sound. what if i bought a new head unit
Also that guy who didnt even try to help just said WTF are u serious ur and idiot why post to bash people help or dont.
if i bought a new deck a cheap like 50 dollar one how do i plug it in the back of my speaker cause in my care i have this giant plug with like 9 wires going in it and then one wire on the right of the back of the h.u, But can i buy something to just plug that plug into and have rca cables? or would i run each indivdual wires
timebomb0220
timebomb0220
new york
iDesignBoxes
