a noob question
  • 4
If a problem arises, hopefully that fuse will blow before your amp.
No, the fuse protects the wire from overheating and burning down the car.
On board fuses will protect the amp (or if a manufacturer does not include on board fuses, then one must be placed at the specified rating as close to the amp as possible)
Yup also protects yours cars electrical if you happen to short out the power, this way the inline fuse will blow instead of all the other fuses in your car lol
No, current travels in the path of least resistance. A dead short is 0 resistance and therefore will only travel through the shorted wire. Electricity doesn't just travel throughout all the circuits.
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
emd2260
emd2260
NY
ultimate157
