gckless
So, I want to get an idea of what would be a good PR setup. Got a bunch of questions. Here is what I have to work with:
This box is for a Subaru Legacy.
About 4.5 cubic feet, minus driver displacement.
Running off a DC 2.0k.
Big 3 done, soon to be a 230A alternator.
I'll start with box design. I would like to build a box with 2 drivers and 1 PR in the middle of them facing the trunk, and one PR on the opposite side of the box facing forward. Both PR's would be centered to cancel out the moving mass. First question is, how would facing the drivers/PR's this way sound?
I'm pretty much set on 2 12" PR's, I'm looking at the TC VMP12's ( TC Sounds VMP 12" Passive Radiator 293-680 ). I would like to use 2 12" drivers, I currently am running a RE SX 12", so only purchasing one more would cut down costs. I know you are normally supposed to use double either the cone area or the Xmax of the drivers for your PR's. The RE's have an xmax of 22mm, which would be 1.7" when the xmax is doubled (xmax is only one way, from rest, travel, correct?) and converted. Since the VMP's have a max excursion of 3.5", would I be ok to use the SX's, or would I need to use 10" drivers?
If I need to use 10" drivers, I need some recommendations on decent ones for around $200 each. They'd be ran off my DC 2.0k, and I am going for somewhere in the middle of SPL and SQ. I do want it to be decently loud, but I would also like something that sounds good.
I really appreciate any help that can be offered. Since I realize this might be a little complicated, let me know if I need to clarify anything!
