6th order bandpass enclosure
What are the two tuning frequencies and their respective volumes (minus all displacelents). You might have the two tuning frequencies close to each other and the pass-band is too small. For 6th orders, that's crucial and will severely lower the enclosures output when the tuning frequencies are near each other. Instead of building pressure, one vent inhales while the other exhales and it almost sounds as if you have a box with two subs working against each other out of phase. You might try putting the two frequencies further apart and then tweaking the volumes of each to get your peak/transient response under control.
The front was .28 ft^3 at 36hz and the rear was .614 ft^3 at 70hz. I'm not sure of the name of the site i was on but i juss typed in the specs i needed and it designed the enclosure for me and it said the passband was 38-87.
ryanjacobs13
ryanjacobs13
H-Ville, OK
ryanjacobs13
