69 chevelle build thread
Sweet ride man, Chevelles are my favorite classic, but I'm partial to 66/67 El Camino's and Malibus. I'm most likely going to be picking up a 66 Malibu project sometime next week. Will be many years before it looks as good as yours though haha
System should sound pretty **** good. What's under the hood and what not?
for now a 402, but over the next winter i have an upgrade coming //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
got the mechman 250amp alt installed today, waiting on two spools of 1/0 from ups to get the wiring done.
finally got some more materials in, 20 ft of hyperflex 1/0 in grey and blue and 4 triple 1/0 battery terminals from knukonceptz. anyway, i finished the mechman alt install up today and wired up the new kinetik up front with a + and - from the alt and two 1/0 grounds to a dual 1/0 kicker grounding terminal on the frame. i always wrap all my wiring in tech-flex and use heat shrink tubing around all the ends. anyways... heres what i got done tonight.
something im sure most of you know, if you grind a nice clean spot down for your grounds, use a little vasoline on the bare metal before tightening down your grounds. it helps with the connection between the frame and grounds as well as prevents any rust from occuring.
final product until i add the two + runs of 1/0 to the rear batt, kinetik 2400.
Love the car! Need to head out to Nashville one of these days and get together with some of you forum guys with serious systems...there are none around my way. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
heres a video i made of my mechman install for their rebate offer, a good chance for you guys to laugh at my southern *** voice //content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif
didnt get a ton noticeably done today, spent some time rewiring the engine harness a little bit. i did finally get the top on the box and give it a test fit tho...
jeepintn
jeepintn
Greenbrier, TN
jeepintn
vegang
vegang
