6 speakers in a 4 channel setup with mixed impedances
  • 5
spikes527
Hey all I'm new to these forums so I hope I'm in the right place... anyway I currently have a 4 speaker system hooked up to my Crunch PZX1200.4. The speakers are 2 ohms so that's 300w per speaker. (even though the speakers are only rated for 150w rms at 2 ohms, but that's another story) I have a pair of 6x9 kickers that are rated for 150w rms at 4 ohms. My question is can I wire my 4 2ohm speakers to one channel (either in a series, parallel, or series-parallel) and the 2 4ohm speakers to the other channel safely? Sorry I know that's a long one! Any help would be greatly appreciated.
No - it's about 60w per speaker.
Yes -- Run the 2 ohm speakers in a series which gives you 4 ohms on two channels. That's probably 40-50w rms per channel so 20-25w per speaker.
Then run the 6x9's on the other two channels which will get you 40-50w per speaker.
It's a much lower stress situation (4 ohms per channel) than it was just running the four 2 ohm speakers (2 ohms per channel).
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
805
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
spikes527
spikes527
Pittsburgh, PA
Louisiana_CRX
    May 24, 2024
    May 23, 2024
