once you play anything higher than 2khz on a sub it automatically turn into a tweeter and you can never use it as a sub again...so beware!//content.invisioncic.com/y282845/emoticons/flamer.gif.1fb8372af2de4b576aa9428ccc8a8f2f.gifmechanically speaking...
is there a problem playing 5k hz on a sub woofer?
hahahahahahaonce you play anything higher than 2khz on a sub it automatically turn into a tweeter and you can never use it as a sub again...so beware!//content.invisioncic.com/y282845/emoticons/flamer.gif.1fb8372af2de4b576aa9428ccc8a8f2f.gif
Note: Subwoofers are called subwoofers due to them playing SUB BASS FREQUENCIES. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifhow about i make it more of a open question.
can i play all different notae on my sub (none below of which it will hurt it of course)
does that mean if i take one of my eminence tweeters and play 30-100hz then itll be a uber woofer!??!?!?!?!? for only 20 dollars?!?!?!?! zOMG:yumyum:once you play anything higher than 2khz on a sub it automatically turn into a tweeter and you can never use it as a sub again...so beware!//content.invisioncic.com/y282845/emoticons/flamer.gif.1fb8372af2de4b576aa9428ccc8a8f2f.gif
