.5 ohm or 2
kw_rock
Would I be better off getting an amp to push AROUND 2,000 watts at .5 ohm or one that can push around 2,000 at 2 ohms (Being able to at 2 ohms would probably implyinh over 2,200 at 1 ohm)
If so, what would be some good amp ideas? Orion 1200/2500, Lanzar opti 2000d, mtx thunder 1501... any other ideas? Also, budget does some into consideration. Anything under 350 would be very awesome... Lol Even under 300 would be awesome.
Well, I would need an amp that is rated at like... 12/14 volts, not 17 like MA Audio... What suggestions would you say for an amp?
closest that I personally like and own is a d300hc. 1750@2ohm 14.4v, all packaged into an amp the size of a stack of paper.
Lol dude isn't a vr2000d like.... a grand or so? Or like... 700/800$ That's a little too much when I could get an amp for much cheaper and probably be just as happy, if not more so.
kw_rock
kw_rock
bumpin_blazer
