4ohm vs 2ohm
Jacobman
CA
Here is my situation, I am getting a system for my car. This includes a new deck which i have decided on the Kenwood Excelon KDC-X589 and 2 front speakers which would be the Alpine SPS-130A's. I am wanting 2 12" Alpine type-r's but i have too small of an amp to power them, the Phoenix gold M25. I would like to buy 1 sub and later on getting another sub and bigger amp, but i was told for some reason you cant have onle 1 4ohm sub. If your getting 1 sub then it must be 2ohms and getting 2 then they must be 4ohms. Why cant you just get 1 4ohm sub?
If that is the case then should i just get the 2ohm one and when im ready to upgrade getting 2 4ohm subs, a new amp and then selling the 2ohm and amp on eaby or something?
get whatever configuration of subs that you amp put the most power out at.
ex: if your amp put out the most power at two ohms, you want a single two ohm speaker or dual four ohm.
for more help use the woofer wiring wizard on rockford fosgates site under tech support.
just get an amp that puts out about 1200-1500wrms @1ohm and about 600-1000@2ohms, so when you have one sub you can wire it to 2ohms and when you had the second sub. it will be 1ohm
I cant get an amp on my budget, I can only get one sub. So should it be a 2ohm one or 4 ohm one. But i do believe the amp puts out the most out of 1x2ohm.
Jacobman
Jacobman
CA
foddercom
