4 gauge wire/40a Fuse
Depends on how much current you're pulling. If your sound system is drawing more than 40A, then yes, it will blow. 4AWG can generally handle 120-150A.
Um, no. 4AWG is 4AWG, welding or otherwise. 95 amps.
No it does depend one the wire. Every company has different ways of making there wire. current handling depends on strand count, wire material, and thickness of the isolation. you should always check with the wire manufacturer to see what they rate there wire at.
There (sic) wire is no different from anyone elses. Their wire is rated the same or less. There. Isolation be damed.
brybry354
brybry354
Texas
KyleBechtold
