4 Ch 6000 watt amp to 2 1400Watt DVC 15" subs how should i wire speakers to amp
The old Boss stuff used to be good before ZED let it go.
Was good but still over-rated by double. Out the gate that company was out to mislead...from there I guess they figured they might as well buy cheap Chinese garbage and sell it for the same price as the USA made stuff and over-rate it even more. AFAIK the ONLY Zed amps ever that were over-rated. F*cking tragic really because the havoc and the CLR series were really nice looking amps and they have pretty good pre-amp features and a solid power supply.
I'd also say the only way that equipment would crack a windshield is if you threw them at it.
Your telling me that amp only does 42.5x4@4 rather than the 85x4@4 its rated at. Steve said they are 30% over rated not 50%. 60x4@4 on 12v isnt bad.
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
kyle1153084
kyle1153084
foster, mo
whitedragon551
    May 18, 2024
    May 18, 2024
