350A ANL fuse
cable size should not determine the amount of draw the amp is going to have. I would use the largest wire you could, as many runs as you can, and use the appropriate sized fuse.
Thank you. I'm only doing one run of 4/0 welding cable. The ampere 3800.1 calls for a 350a so that should be good. Cause I'm ordering a whole bunch from a page that requires a minimum of $25 purchase that makes it 8 350a fuses //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
elchemo1986
Coldwater,mi
michaellane
