T trigga_b 10+ year member Member 137 0 chicago May 5, 2006 #1 if you had a choice to run your subs in 2 or 4 ohms with the same output rating which would you go with? Click to read more...
Beat_Dominator 5,000+ posts Yea, thats Mecha Godzilla 22,317 69 Phoenix Arizona May 5, 2006 #2 4, easier on the amp in most cases.
OP T trigga_b 10+ year member Member 137 0 chicago May 5, 2006 Thread Starter #3 to be more specific....2X4ohms = 200w (amp1) or 2X2ohms = 200w (amp2) the amps are different, i haven't decided on an amp yet.
OP T trigga_b 10+ year member Member 137 0 chicago May 5, 2006 Thread Starter #4 i been tryin to decide between the type r 12" and the kicker L7 12" for a week now and still isn't sure
Beat_Dominator 5,000+ posts Yea, thats Mecha Godzilla 22,317 69 Phoenix Arizona May 5, 2006 #5 Lower ohm rating at the same power output means more current....and more heat. Less heat leads to longer life and less fuss with fuses blowing and the amp shutting down due to overheating.
OP T trigga_b 10+ year member Member 137 0 chicago May 5, 2006 Thread Starter #6 with the dual 4ohm coil you can always wire it down to 2 ohms right?
OP T trigga_b 10+ year member Member 137 0 chicago May 5, 2006 Thread Starter #8 what kind of cheap good amp would you suggest to run 2 type r 12"s
Beat_Dominator 5,000+ posts Yea, thats Mecha Godzilla 22,317 69 Phoenix Arizona May 5, 2006 #9 Hmm, everyone likes the Hifonics amps for lower cost. If you don't mind used there are some great deals on ebazy and stuff.
Beat_Dominator 5,000+ posts Yea, thats Mecha Godzilla 22,317 69 Phoenix Arizona May 5, 2006 #11 Might find help in this thread too: http://www.caraudio.com/forum/showthread.php?t=157886&highlight=amp+type
