2500.1 Questions
Mr. Nipples
Pimp ***
I've got 2 kicker 2500.1's and one is hooked up to power 2 of the 4 l7 15"s i have in my focus. Problem is when the voulmes up, the amp will cut out completly. Im guessing its a voltage problem due to the factory alt and battery but thing is, I cant get an upgraded alt for my 2001 focus. I asked around and from what I hear it doesnt seem like they are made.
what should i look for other then a ground issue for the reasoning of it cutting out? its not the impedence I know that for sure because that kicker amp can do just about anything you throw at it.
Thanks in advance pals.
those amps are regulated power supply, so rather than getting less and less output, they will just cut off if there's not enough voltage/amperage to make power within the supply's tolerances
call dom. he might have something for you, he had something for my car... and it's an oddball
im not runnin em daily like that
i just know they will take that low of an impedence and still stay reliable. there was a dude on here running one daily to a L7 10" at .9
Mr. Nipples
Pimp ***
Mr. Nipples
Grand Rapids
Chevyaudio
