23-2700 watt Fiberglass sub box recommendations
  • 2
Rcn11thacr
Scouts Out!
14
USA
If you were building a sealed box which was intended to withstand between 23-2700 watts of power, how thick would you make the box?
This will be holding a single sub. My understanding from various manufacturers of sub makers, using a sealed box w/ a single 10 inch sub, @1 cu ft, with 600 watts = 1/4 inch if the box material is fiberglass.
What do the experts say or think?
You aren't putting a 2700 watt sub in a small sealed fiberglass enclosure bro. Or at least I hope not but if for whatever reasons then just do the math. 2700/600=4.5. .25x4.5= 1.125
Hah, maybe I didn’t clarify that. I’m not planning on putting this in a ‘small’ box. My goal is to use the strongest box material possible so I can have shave the overall wall thickness of the box. Fiberglass being much stronger than MDF, etc, I can have more room inside the box for the sub. I have limited space available that I wish to make use of so I want to maximize the interior size of the box. Make sense?
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
Rcn11thacr
Scouts Out!
Rcn11thacr
USA
Rcn11thacr
SlugButter
    May 4, 2024
slater
    May 2, 2024
