2013 F150 FX2 with factory Sony/Nav/MyFordTouch
KBT2014
The truck: 2013 F150 FX2 fully loaded
Equipment:
Image Dynamics CXS64v.2
Image Dynamics CTX coax
Arc Audio XDi 1200.6
Audison Bit Ten D
Sundown Audio SD-3 10" (preordered an ID 10" will be a temp sub)
Fox box
Fatmat Rattletrap XXX
Goals:
For now the system will be ran passive but I am mounting the crossovers at the amp rack so I will have two runs already to the doors if/when I decide to go active. I will tap the factory signal after the Sony amp and run the front mids and rears to the bit ten. I also want to do a similar mod as shown by Soundman to get an optical audio input into that bit ten.
Progress:
So far I have done sound dampener, made amp rack, hopefully this coming weekend I will be able to finish the truck up. Here are some pics.
nice start! how are you running your wires from the cab to the door speakers? I have a 2011 f250 and can't figure out the best way to do this.
You ever get that figured out? I'm about to start on same model.
Sent from my iPad using Tapatalk
Does the model have the plastic plugs preventing running wires from the cabin? If so most people dremel out part of the plug to allow new wire through
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Anyone? Anyone? Looking at the audio control d 6.1200
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
Excellent for good sound stage and imaging, don't expect it to move your mirrors or anything. Honestly with what you're trying to do just doing...
KBT2014
KBT2014
West Texas
bandit_kb
    May 16, 2024
    May 16, 2024
