2011 Chevy Silverado 1500
  • 2
rvwisneski
So I had this great idea to replace my factory deck with a aftermarket. I can get the deck to power on when I hook both the constant and the accessories wire to the battery cable. I am assuming this is the red/white wire is constant power. On the new harness the yellow cable is labeled batter. I tried hooking the radio up to the dark green. It gives some odd results to the accessories, but does not power on. Any idea what I might be doing wrong? Yes, I have hooked up the ground(black). Any help would be much appreciated.
With that truck you should really buy an aftermarket integration adapter/harness. Hopefully you haven't backed up the factory harness. To answer your question yellow should be constant power and red should be switched accessory power. If you don't use an aftermarket adapter you will lose turn signal clicking sound and warning chimes.
I cut the harness, but I will just buy a new Chevy harness kit and rebuild it. So a $60 radio has just doubled. Lol. At least learning lots. Thanks for the reply.
Probably the adapter brand. Other users have found that the pins do not coincide with the factory pinout guide. They have solved this by pulling...
HUGE thanks to everyone who contributed in here to helping me determine my amp was the issue. You guys were great. I now own a multimeter which...
53
5K
Hi crew! I’m reaching out for some help. I have a 2011 Fiesta SES and have all the parts needed for a conversion to Sync 3 except the harness...
Ok. I think I get it. There's really not much to be gained between charging them at say 60% and 100%. At least not on a daily system. Please...
13
rvwisneski
rvwisneski
Mesa, AZ
rvwisneski
slater
    May 2, 2024
slater
    May 2, 2024
