2009 Build Log for Bumpin Buick
That's what loud people do //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
SS1-2?
If you call 4ohm on a stock alt in a box built about a foot to small then sure lol. Its no where near loud, I just dont have the time to put in the HO alt as I need to pull most my engine apart and my batteries are down in Whitewater. Sucks working two full time jobs.
I will be running two or three vehicles at dropfest though assuming I can get the TB done. 2 Orion HCCA 2100s on 2 DC lvl 4xls... should be interesting.
But yes this will be SS1-2 sadly, or I could do Streetmax... but then id be up against you and no thank you.
how far off is that port from your rear hatch?
3 inches but I can push the box back another two or three if I want, havent messed around with it yet, meter comes out tonight so I will adjust accordingly
how are you goign to stop the back glass from rattling?
well the glass is sealed all the way around as its a motorized window, so that helps a lot. Also the whole hatch has three layers of Raamatt BXT. It wont be flawless but it should help a good bit.
3 layers is illegal for db drag //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif (unless your in SS or SM and its behind the B pillar)
A total of 2 layers with a max thickness of 4mm is all you can use.
bumpin buick
Science is everything
bumpin buick
Appleton, Wisconsin
bumpin buick
