AMP RECOMMENDATIONS FOR Treo te's
Braskii,
Depends on your coil configuration for the TEs... but we have had great success matching up single TE 12.22s (parallel to 1-ohm) to the new TREO RSX 1500 monoblocks. Easy 500 watts RMS per sub will do it right, sealed or ported. The TE is a very accurate and clean sub with great extension and output.
If you want, you can run 1 amp per sub, or pair both to the new RSX1900 (900+++ watts at 1-ohm) if you've got a pair of 12.44s.
Regardless of amp brand, they are rated to handle 500W RMS, but as you know they are built to take a little more. I'd be OK with 500-600 real watts per sub.
But I'm a conservative kinda guy. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
PM me if you are interested or want to discuss.
Thanks!
Braskii
Braskii
Omaha, NE
MobileAVC
