2000 watts rms @ 2ohm
How's his electrical?
This is why I was not leaning towards .5
I'm doing the big three before my install. And I will run new 0 gauge also. But I've read .5 is harder on the battery and alternator. I mean I will eventually upgrade both but not right away.
Sent from my SM-G935V using Tapatalk
.5 or 2ohms I don't think makes a big difference in terms of current pull
rise is usually a lot higher at 2 ohms so technically you arent getting as much power as half ohm pulling less current than half ohm. Efficiency tanking is also another factor.
On paper and resistive loads then yes it shouldn't make too much difference.
Just picked up 2 skar ddx 15s d2 for a steal. Looking for an amp that can power them at 2ohm. Don't want to break the bank. Right now I'm considering 2 of the rp1500.1 or 2 of the lp1000.1
Thoughts??
thought u were gonna run 1? at least amp would be much easier then + box for 2 15's is large
Still up in the air. I want to do both if I can make it fit. If that's not an option I'll sell/trade 1.
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
The last piece and the system is a wrap, RUX-H02 remote volume/sub knob because we are old and buttons **** IMG_0647 by Jon Polo, on Flickr...
Jhicks
Jhicks
Henderson NC
BOOMINGRANDPA
    May 22, 2024
    May 22, 2024
