2000 Ford Mustang Install Problem.
  • 2
Mr.Strike
I bought a Kenwood deck to go in a 2000 Mustang. I want to install it my self. I got every thing I needed, or so I thought. The guy at the Best Buy install bay said I had to bypass the factory amp. In the Mustang it has the deck with the tape player and the CD player as seperate units. The wire harness I have has two connections one black and one gray. Now, I do not know where to plug up the black harness. I unhooked the factory amp completly. Does anyone know where I can get an install guide specifically for a 2000 mustang with the premium sound package? Thanks in advance.
Originally posted by Mr.Strike I bought a Kenwood deck to go in a 2000 Mustang. I want to install it my self. I got every thing I needed, or so I thought. The guy at the Best Buy install bay said I had to bypass the factory amp. In the Mustang it has the deck with the tape player and the CD player as seperate units. The wire harness I have has two connections one black and one gray. Now, I do not know where to plug up the black harness. I unhooked the factory amp completly. Does anyone know where I can get an install guide specifically for a 2000 mustang with the premium sound package? Thanks in advance.
it's simple-----------one of your plugs should go to the speaker wires that WHERE after the factory amp -----as you have by-passed it. the other is just for power and most likly only fit one other plug--------if it fits more than one --- plug it in and test the wires for power with a voltmeter.
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
3K
The last piece and the system is a wrap, RUX-H02 remote volume/sub knob because we are old and buttons **** IMG_0647 by Jon Polo, on Flickr...
5
Mr.Strike
Mr.Strike
Arkansas
Mr.Strike
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
