2 planet audio 5000.1d 4 12" orion xtr subs
  • 4
Jamie86
I had one of planet audio amps pushing all four subs at 1 ohm being that there stable at one ohm liked what I heard but thought I could get more out the subs if I got another amp to push 2 subs per amp at 1 ohm but I don't know how I should go about supplying the power for this setup. Should I use another battery or power cap or both.
Help so confused
What series amp is it? Anarchy? I guarantee its not doing anywhere near 5k. But most likely you need to read up on the big three, run some 0 gauge, and have a good battery up front and some support near the amp (more batteries). If your close to 3-4k rms, you may need a HO alt. Also we don't use caps, they are worthless besides an inaccurate voltage reading. Get a good voltage meter in your dash or where you can keep an eye on it and keep it above 12.5v
So yu don't think I can get 5k outta the setup I have?Oh and yes they are anarchy series amps
not even close to 5k from that amp unless its struck by lightning. you may be getting 1.5k from that amp @ 1 ohm on a good day..... trust me i have a pretty good amount of exp with planet audio amps....
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
A Link would be very helpful. Id be interested in taking a look at some gear
195
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
Jamie86
Jamie86
Lafayette, La
Jamie86
