2 planet audio 5000.1d 4 12" orion xtr subs
Jamie86
I had one of planet audio amps pushing all four subs at 1 ohm being that there stable at one ohm liked what I heard but thought I could get more out the subs if I got another amp to push 2 subs per amp at 1 ohm but I don't know how I should go about supplying the power for this setup. Should I use another battery or power cap or both.
Help so confused
What series amp is it? Anarchy? I guarantee its not doing anywhere near 5k. But most likely you need to read up on the big three, run some 0 gauge, and have a good battery up front and some support near the amp (more batteries). If your close to 3-4k rms, you may need a HO alt. Also we don't use caps, they are worthless besides an inaccurate voltage reading. Get a good voltage meter in your dash or where you can keep an eye on it and keep it above 12.5v
So yu don't think I can get 5k outta the setup I have?Oh and yes they are anarchy series amps
not even close to 5k from that amp unless its struck by lightning. you may be getting 1.5k from that amp @ 1 ohm on a good day..... trust me i have a pretty good amount of exp with planet audio amps....
Jamie86
Jamie86
Lafayette, La
Jamie86
