Alpine Imprint Help
z411811
First off, heres the system.
Code:
Headunit: Alpine CDA-117
Commonents: Massive Audio CK 6X
Rear: Polk Audio DB691
Sub: 15 inch DIgital Designs 1000 series
Speaker Amp: Precision Power Sedona S580.4
Sub amp (bridged): Precision Power Sedon S580.2
I was just gifted Alpine Imprint for christmas. I dont know what setting to put the sound processor on. I think my system is 2 way active but im pretty new to this. The switch says either 3 way or front/rear/subs. Thanks for any help in advance.
2 way + sub, what switch are you speaking of?
Also assuming you did this, did you connect the imprint via AI-net? Did you swich the control switch on the bottom of the 117 to EQ?
Does the 580.4 power the comps and rear?
Yes it does.
Theres a switch on this side of the imprint. And yes I turned on the ones bellow the HU.
You want front rear sub. You are not active. To have active you would need to remove the passive crossovers on the comps and replace with the four channel amp. The tweeters each have there own and mids have there own so you can "actively " control the crossover settings.
z411811
z411811
Detroit
dbjunior
Mike Mccabe
