2.2v pre vs. 4v pre on HX2 12inch
  • 4
ilmaoalot
PA
Hey guys, I recently upgraded my headunit to a pioneer deh--580mp, and the pre outs are at 4v compared to the 2.2v i used to have on my old one, some aiwa model. My sub is hitting a lot harder, and is playing louder!! I checked the gains, and everything appears to be set right, does a higher output just give better quality, or do i really have too much power going to my sub?
ok when u said you checked the gains did you reset them? higher preout voltage means you have to drop the gains to compensate , just like if you droped the preout voltage you would have to raise the gains to compensate
ya, my gains are turned down as low as they can go, and i set it like you are supposed to, but my sub is hitting generally harder is that bad?
higher pre out voltages do not make you system louder it benifits because the amps can put out the same ammount of power with the gain set lower than it was before but the amp puts out the same rated power at all the input voltages that it accepts.
I just bought an Alpine R-A75M for my sub woofers, and later plan on adding the Alpine R-A60F. My plan was to wire these with 3 sets of RCAs; one...
yeah that, just as long as your amp can take the voltage. I have an orion amp that maxes input voltage at 4V.
Sounds like you need new coils. My Explorer with three 15's, appropriate birch box, fully sound-deadened interior, and a boat behind it does not...
Ive competed in car audio since 1991 and unless something is faulty in the amp and its staying on all the time it wont drain your batteries ..the...
ilmaoalot
ilmaoalot
PA
knotslck
    May 18, 2024
    May 16, 2024
