2 15's in extended cab s-10
Are you wanting to remove the rear seats or do a blow-through?
Both have been done. Lots of people can give you input on either setup. Which is great.
Let me see if I can find some build logs for you.
here is a video to kinda show u my setup same box and subs zv3 12" subs ,but upgraded amp last winter to a taramps hd 8k, was looking to do a pair of zv5 15's if possible or a similar sub
zv5's are solid subs.
Bit of a heavy ticket imo but if you have some cash for them then not a bad buy at all.
On 8k those subs would be happy.
SSA just released all new revisions to their subs. I would check those out if you haven't already.
Specifically the new Zcons. Would give those a gander //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
If you're wanting to stick with sundown, then zv5s would be your best bet for sure.
Yeah sub brand is not a big option , just want to stay with something similar to a zv5 , just needing to see if I can get them into the cab my s10 ..
I already posted a video showing that 2 15s will fit no problem. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
We also built a 4 12 4th order for an s10 extended cab but it was a wall.
yeah I don't mind going past the window as long as it's not totally blocked, I left a comment to hopefully see if he has box plans still
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
buckeyes#1
buckeyes#1
p-town
Boomin_tahoe
    May 16, 2024
    May 16, 2024
