(2) 15" sub box build in the back of a 2007 dodge caliber. 7.55 cubic feet. help?
they arent gonna give you what you want. id suggest 2 sundown z15s since they like smaller boxes idk bout that small im using 12s atm and they seem to do ok at 2cubes a piece in 1200 a piece
yea, i was looking at the sundowns, but there like 200 PER sub =/ im up to 400 without an amp =/
you not even in the right ball park on this... you want to brag and dont want to spend 200 on a sub? if you arent willing to pay then you probably shouldnt even try to play the game.. CA is expensive, and in my opinion if you buy cheap equipment then your probably going to regret it unless your expectations are low.. you say you have around 4 cubes if you use a simple design, perfect for a single 15 that you could probably find a very good used one on here that would handle about 3k without a problem... again this is my suggestion and i dont think your going to listen, but if you built a proper enclosure for a 15 and had a quality sub with a good amount of power you will be louder than 2 low powered subs that wont last...
well i built the box design that i had pictures up of(basically, tweaked it a bit more). i got 4 10" pioneer subwoofers for it, have 2k watts, and it hit way harder then my friends professionally built 15 could ever wish to hit. nad ive got about 280 in it. not 2grand.
Um, I guess congrats. However, just because a shop built an enclosure does not make it "professionally built". Many shops will pass of prefab enclosures as custom. I'm not saying your system is bad or worse..just saying it is hard to compare setups by word only. Maybe you should get your setup on the termlab and see what kind of numbers your doing. Never know could be doing better then most on here may think.
joe913
joe913
tucson, AZ
pro-rabbit
