2 10s Mid Port Box Build Log
GearGuy2001
Well yesterday I got around to cutting my pieces for the box and today I wont get a chance to glue/screw it till later so I figured I would test assemble it w/o fasteners or glue
It will be around 1.15 Cubes for each sub the port is tuned to 32hz
I forget outside exactly but I think its 34.5x14x13(Ill update with exact later)
The Main port is 2.5" and obviously the secondary ports are 1.25"
Pictures
Also this is my first box
fvck i wish i had that kind of space to work with
all ive got is my driveway or in the house if the weather is bad
looks good so far
Yeah thats our basement, I cut em in the garage (on the new table saw woot)
Youll have to excuse the mess we just moved in back in December (new house so we are putting in the yard and stuff 1.2 acres *****(for putting a yard in) fyi)
Any time I want to paint the winds pick up to atleast 30mph so.... Its sitting outside waiting for tonight to come (and the winds to die off) so I can paint the port.
More Pictures after the paint
New Pictures
Almost Done Painting
The Right side isnt attached yet so I could easily paint it but the Left side is screwed and glued
Inside the Box (titebond 3 works pretty good)
The car its going in (yes the wheelbarrow tire is flat)
Finished Painting
Got the right side speaker assembly attached today, going to put the back on tomorrow and to make it gank resistant (sorry almost forgot nothing is proof) I picked up some stainless carriage bolts to bolt it through my trunk
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
Good explanation, thanks. I'll try installing that other amp soon. I have a stinger cap that shows my volts. It's reading 15v at max volume with...
17
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
GearGuy2001
GearGuy2001
South Beloit, IL
Bun-Bun
    May 12, 2024
Brendon Jenness
    May 11, 2024
