1st truck box attempt - FREE box build
ls2poweredgoat
Womanizer
Made two of these, the other one isn't quite finished and is sitting in my room.
They're about .75 cu ft each, for a 10" woofer. The buyer is cutting the hole out himself to be safe, since we couldn't find specs on the sub for hole cutout diameter.
Don't be too harsh, it's my first truck box I've ever made. Bear with me!
There is a 1.5" indent at 12" high for clearance in his reg cab S10. It isn't the prettiest box I've ever made, but it is SEALED.
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thanks. For my first attempt at a truck box I didn't think it was all that bad.
FYI he is covering the boxes in carpet. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Yeah, it looks like a lot of cuts.. Must have been fun //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I get sick of cutting after 8 pieces for a ported box.
It was a PITA, they both were. I'm glad it's over. I just have to finish putting the other one together.
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
733
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I honestly think that stock locations work great for 90% of the people. With today's DSPs, you can move the listening position anywhere you wish...
943
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
315
ls2poweredgoat
Womanizer
ls2poweredgoat
Port St. Lucie FL
OoMesKoO
DEW123
    May 7, 2024
DEW123
    May 7, 2024
