1998 Dodge Ram "Budget Build"
kahoproductionz
UFA
3/4" MDF cut to specs:
Did some painting first:
Got da sides and da inside port glued and screwed and put into place:
We no more clamps (da longer ones) so we jus had a scrap piece for a brace:
Making sure the port is same from front to back:
what subs are u gunna run?
info on what you're running //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Subs/power
Gotta think "Budget";)... my homeboy's got FOUR 12" Kicker Comps he wants to drop in dis BOX. He had 2 comps already in a pretty badly build sealed box. I told him, c'mon man... let's build a REAL box for deez subs. Anyways, he should be picking up another 2 Kicker Comps from a fren for like dirt cheap.
As to power... he's currently running a Rockford Fosgate Punch 1000.1bd. Enuff to power ALL FOUR Kicker Comps.
Jus' gotta remember... "BUGDET build"... times are tough... not enuff money to go toward a bad-ass system like most of y'all.
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif you should invest in some grammer lessons, not car audio. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif but the box looks good
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
987
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Hello all of you, unfortuanally as mentioned before it isn’t possible to get fader with this setup: Pioneer radio 4 way output and a factory amp...
26
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
kahoproductionz
UFA
kahoproductionz
Provo, UT
kahoproductionz
    May 31, 2024
    May 24, 2024
