1965 Ford Econoline Soundstream Install
  • 5
THUMPPER
Pound That Sound
a very unique ride..thought I would post
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
1. Sure, it would function but it would look a little half arsed. Ideally you would use a distro block and run separate wires to each amp or...
763
678
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
THUMPPER
Pound That Sound
THUMPPER
Salmon Arm BC Canada
Louisiana_CRX
audiobaun
    May 19, 2024
    May 19, 2024
