18" FI Q Installed
FUCK!!!!!!!!!!!!
so I get in my car to go to work earlier, and the frickin battery light, AND brake light were on for the first time....
THEN, im at work.. We close at 10... someone was leaving the store... came back in to say, "HEY IF YOU"RE PARKED IN BACK, YOUR CAR MIGHT HAVE BEEN SPRAYPAINTED" I go back there... YEP... my car got spray painted all over the trunk/tail lights (aftermarket) and rear window.... my car... along with 5 others.....
Back of my store is located right next to a highly populated foreign/illegal know apartment complex full of russians, polocks, and mexican...GO FIGURE... its a mini L.A.
ooooooooooooooooo.mmmmgggg
Just tested my battery while connected to the car, car OFF, 12.45... NORMAL....
Turned the car on.. 12.35!!!! WTFFFFFFF IS GOIN ON!!!!!!!!!!!!!!!!!!!!!! WHY DO I HAVE THIS HORRIBLE LUCK WITH EVERYTHING!!!!!!!!!!!!!!!!!!!
So car on is less than car off... does this make any sence!?!?
i'd just like to be able to do it the right way...with a DMM, but for whatever reason it isnt reading like it should.
You said you are setting bass to 0....you are not setting your sub output level to 0 are you? That should be all the way up
no no... gain starting all the way down... BASS on the radio set to 0
regardless.. I gotta figure out WTF is happening with my battery issue now
If you have ur sub plugged in and have base to 0 is there output?
thank you for the quick reply ,I contacted LordofBass and the part is backordered but I'm on a waiting list Cheers:)
The install looks very nice and clean for sure. Thanks for sharing the pics as well as your experiences
snb778
blaugh!!!!
snb778
ex. Los Angeles, CA
snb778
audiobaun
    May 19, 2024
    May 19, 2024
