150dB Trunk Build - 2001 Honda Civic Lx - 2 DD 9515G + 2 Sundown SAZ-3500d
If you flush mount it, that will be fine. I just don't think you should get them any closer to the roof of the trunk. Even another 3/4". You need as much clearance between the subs and the roof of the trunk as you can get so the pressure can get into the cabin. It's already lagging behind the port. No need to trap it any further.
It is sometimes beneficial to have them loading off of a wall, but I don't think that applies in this case.
I see what you mean. I have the rear deck off so ive got factory speaker holes to help get some of that pressure out. I think if i cut away some of the rear deck it will help as well.
Got about 6 inches to the top of the roof
---------- Post added at 12:02 AM ---------- Previous post was at 12:02 AM ----------
Can you do threaded rod?
yeah i was thinking about doing that
looking good,gives me the confidence I needed to know I can stuff a proper spec box in my 1.7EL for 2 RE SE15s //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
are you running your stock alt? hows the voltage drop with those batteries?
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
795
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
Drummer65
Drummer65
Newport Beach, CA
DB-Audio
    Jun 1, 2024
    May 31, 2024
