150 amp fuse for a 80 amp alternator. big 3.
  • 4
You fuse for the wire. 300 for 1/0 ofc
you guys are doing it backwards. you size the fuse for the source and load and then size wire to be greater than the fuse.
In totality, you fuse for the wire AND the load AND the source... and the minimum size is used. fuses provide short circuit protection of the source, over-current protection of the wire, and over-current protection of the source and load. example, if the amp doesn't have onboard fuses, you size the fuse for the amp recommendation. you can have an 80A fuse on 1/0 wire.
the problem with 300A fuses is the amount of current they let through in a short.
i size fuses for the source and load and use wire sized greater than the fuse rating and then up-size wire for voltage drop. the result is 100A-150A fuses on 1/0 wire. perfectly fine and safe.
the only concern with using too small of a fuse is nuisance blowing of the fuse when the load demand is greater than the fuse size.
for the big three, the batt to alt wire needs short circuit protection for the battery, over-current protection for the wire, and overload protection of the alternator.
a 100A fuse is fine for the alt to batt wire, especially when in parallel with the factory wire (which means each wire sees only half).
I see "fuse for the wire" all of the time. and as a result fuses are oversized and sources/loads are not protected. it's a regurgitation of a statement without understanding.
the above method is how you account for all three aspects of fuse sizing. if the source or load can be damaged if current is greater than what they are rated to handle, fuse sizes are smaller than wire ratings.
I'm not gonna get into a pissing match. I agree with fusing for the source to a point. If your 4 channel amp has internal fuses honestly you don't have to fuse for that source. It's like putting two fuses inline right next to each other. For amps that require external fusing, you fuse as close as to possible to the amp, the fuse at the other end (origin of power), should be fused for the wire.
If you have a H/O alt charging your front battery, you would not want a 100a fuse because you will cause unwanted resistance at the point of the fuse, resulting in power loss and added heat at the fuse AND alternator. I would then fuse for the wire and output of the alt, which would be 250-300 most likely.
All my amps have fuses built in, so I just fuse to the wire. My alt is rated more than my max fuse size, but I know fuses can take more than rated before blowing.
If amps are internally fused, do you still have to fuse for the load?
I wouldnt spend the funds on that amp if you have no way of knowing it works or not. Id purchase another 4 ch for that kind of money. You just...
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
352
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
I'm finally getting back into building a system after many years. I figure I'll document what I do. Here's my truck I initially wanted just a...
The Camry
Hey, I Try.
The Camry
Western Oregon
adulbrich
    May 16, 2024
    May 16, 2024
