15" rl-p's in a camry
i had my 2 15's in a 5ft, 6ft, and 7ft. off ~750 per sub. i would go w/ the 5ft box, for the both of them. tune @ 31Hz.
tell this dude that keeps telling you 8ft to step off. if you got a 14 cube trunk then 5ft+port should fit in there pretty easy.
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
I am going to have to pull it out of the dash and have a look again to see if the wires are correct. I sent over this with a pro shop many times...
ramsizzle
ramsizzle
chicago, il
ramsizzle
    May 31, 2024
    May 24, 2024
