which would be better for spl? and then which would be a better all around daily used subwoofer?depends on weather your talking about sound, or output
cool thanks. How can you tell that though? Can you see this just looking at the specs? I'm just wondering so I can quit asking "which is better"imo... a type R would prolly get louder, while the SDX10 would sound alot better while losing some output
I would have swore the last time I looked at the 15 that they mentioned a 10 on there as well.The SDX10 is brand new. Pre-order just started today and no information had been publically shared yet.
The SDX10 differs in many ways from Exodus Audio's DPL-10. As someone mentioned earlier, the motor is much smaller; this is because they are designed for two different applications. The DPL-10 is designed for large sealed, infinite baffle, and dipole alignments...it is intended to be a much higher Q driver than the SDX10.
Great value at $115 shipped.
whats that?The SDX10 is brand new. Pre-order just started today and no information had been publically shared yet.
Are these DVC or SVC, 4ohm or 2ohm? I'm pretty ignorant on sub specs, but want to make sure it will match my Alpine T707(?) sub, which outputs 340wRMS x 1 at 4ohms (don't believe it's stable at 2 ohms, but I could be wrong)
this seems to be on sale for $65 right now, hmmNot sure..
Here is one for $95 http://www.diycable.com/main/product_info.php?cPath=24_93&products_id=674
Thanks for the quick reply. So I should bridge my amp and wire the single woofer in series, thus presenting a 4 ohm load at 340rms bridged?They are dual 2 ohm.
looks kinda like IB in setup. the sub setups I've seen usually have 2, 1 on each side of a tall baffle. The subs have VERY LITTLE mechanical noise, if any, to be good dipole drivers.whats that?
Are you sure the CSS SDX10 is DVC?They are dual 2 ohm.
