10" DC level 4
bolt method is pretty much the same thing as a binding post =). but if youre running that much power you dont want some cheap terminal connector with the cheap wire to be the weak point
id recommend binding post with some 8 awg instead of that cheap stuff =P but thats jsut me.
I thought about that //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif but only after i routed out that big ass hole
HQ photos!
Not reverse mounting the sub but it looks good that way.
My project assistant in a different box //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif:
is that textured paint? like the bedliner stuff?
I WISH!!!! God that stuff is expensive! It is textured yes.. its a rust-oleum product called multicolor textured in Black... like 5 buck a bottle
probably not the most durable stuff but still looks decent IMHO
shoulda laid down a few layers of regular spray can black before the expensive stuff
HAHAHHAH bro nothing here is expensive //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I used 3 cans of primer though.... which ran me just under 20... and you are right.. a base of black would have darkened that top coat of texture which is more what i wanted... but i have a feeling that with a few more coats It will darken up.
Factory. 2021 Chevy Silverado custom trailboss
714
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
746
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
645
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
Jaredturp
Jaredturp
PA
Jaredturp
    May 24, 2024
    May 23, 2024
