socamonarch
Hi I own a JL audio vantage stealhbox for 94 and up Integras (it sits in the spare tire well of the car). I bought it without the speakers since i wanted something with a higher power rating than the recommended 3 JL 10W0 or 3 JL 10W1's. Here is a picture of the box
http://www.geocities.com/southern_so...box_Acura.html
The gross internal volume of the box is 1.75cuft which should give me 0.58cuft per driver.
I have seen ppl put JL audio 10W3's in the box (the speaker has a mounting depth of 5.75 in so they needed (3) 1/2in spacers for clearance or some ppl have used 1in thick weatherstripping to seal it)
Here are the actual dimensions of the box:
Dimensions : Outside 26" wide x 31-3/4" Long x 7" Deep
Inside 21" x 25" x 5/3/4" Air space is 1.75 Total
I wanted to know ppl's thoughts about some other 10 in subs that I could use.
For example I was interested in the new Memphis audio M3's (15-M310).
For power I am using a rockford forsgate 25 to life Power 1000 amp.
What are the best subs that I can use in such a limited space?
