1/4" MDF for ports?
SPLThunder
In order to make a large box in my trunk i need to make the slot ports out of something that is 1/4" thick. I think this is ok because they are just ports but i dont know what would be the best material to use becasue 1/4" isnt very easy to screw into. Is this ok and should i use mdf. Would glue and brad nails work better?
They are completly external slot ports.
Is 84^2 inches good for port surface area. The port velocity would be low enough but for SPL applications do i need to take anything else into account.
I don't know if ports have any real stress outside of their construction, so I can't really give much advice on that aspect... However, if you do end up using it, I wouldn't screw it in or screw it together, I'd construction adhesive. After my recent experience with the stuff (posted pics earlier; I had to completely destroy the front panel from my box to get it apart!), I'm a believer //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
the top and bottom of the ports will be 3/4" and the sides of 1/4" will be screwed into the top and bottom. It will help with some. The ports will also be pretty snug up against the side of the trunk. If they arent tight enough i could brace them with something else very small.
edit: 300 POSTS.......BONG //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
4
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
The late 80's early 90's car's OEM speakers were of the same quality as today's offerings. The main difference was the rear speakers were enclosed...
10
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
12
SPLThunder
SPLThunder
SPLThunder
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
