noob help
  1. Cameron Harris
    Compatibility of JL Audio CP212-W0v3 with Kenwood eXcelon KAC-X401M
    I’m a newbie and I plan on buying JL Audio CP212-W0v3 dual 12” subwoofers and own an old Kenwood eXcelon KAC-X401M, and was curious if they would match up, and/or the amplifier is strong enough for the subwoofers?
  2. DoggoChrysler
    Can anyone suggest a setup so when I get out of my vehicle i can hear the subs from about 10ft away?
    I currently have Four 12 inch speakers in two non-custom boxes and neither are ported. Two of them are Kicker Comp 12 inch subs(THE YELLOW ONES) and then i have two Pioneer 12 inch subs but i have no idea what kind until i go look in the morning. I have an unknown 1800 watt amp that i can...
  3. -Teh-
    Rockford fosgate P300-1 Punch
    So I'm receiving some clipping or what sounds like clipping to me from my amp. It's just the amp I installed an older amp and it works perfectly fine with the sub never had an issue with it but it's a poor quality amp and I wanna see if I can get this rockford fosgate amp to work. I've taken the...
  4. L
    Help with new build, 2001 F350
    I hate to be that guy, but I've recently put together an audio system build for my 01 F350 and was needing some advice. The stock sound system isn't cutting it anymore, and this is the first time I've driven something bigger than a Miata so I wanted to start going big(within a budget) and...
  5. K
    Noobie to the Audio scene, need advice
    Hey guys this is my first post to caraudio.com. I need advice on all the items i need. I was given a Kenwood KFC-WS12 from a friend. I have a 2002 GMC Sonoma 4.3L I have a very basic knowledge of audio systems, but i do have experience in computer and mechanical systems, also understand...
  6. F
    Help Decide On A New System
    Hey guys. I just joined the forum so idk if I am doing this right. But I just sold my Orion HCCA 10.2. I think I am looking to get 2 12's or something that my amp can power. I think I wasn't getting enough power to the HCCA to get it to its fullest potential. I was looking into getting 2 RE...
  7. T
    HELP Troubleshoot Truck Audio System Install
    I have two type R 12" subs that are 4 ohm dual voice coil. I have my subs wired down to 2 ohms since they're dvc. They aren't seized or blown I've done the battery test multiple times. I also have a hifonics Brutus BRX 2000.1D amp. Recently I was having grounding issues in the cab of my truck...
  8. S
    Noob needs help with new system and compatibility
    So I have a 2001 mustang with the mach 460 system. I know that it runs on 8- ohms and needs to be rewired with new amps to get after market speakers to work. I'm looking at purchasing a Kenwood kac-8406 4 channel amp that puts out 900 wats max. I want to hook up my two pairs of 6x8 kicker...
  9. H
    Need help putting together an audio setup without a sub woofer.
    Hey guys, I'm new to the whole car audio system thing, so bear with me. I drive an 08 Chevrolet Cobalt LT (Coupe, no OnStar) and I'm looking to upgrade from the car's stock audio. I'm looking to do a setup that has decent bass, but I don't want to dump hundreds of dollars on a sub, enclosure...
  10. F
    Could use some help picking out amps
    hey whats up everyone i m new to car audio and i have a buddy helping me but he hasnt had much time and i bought a buch of stuff. im at the point where i need 2 good amps and i could use some help.so i just purchased Kicker DCVR122 (07DCVR122) enclosed subs, pioneer DEH x9500bhs head unit, a...
  11. K
    Can I keep my stock CD changer and change out the face?
    I'm not a car audio techy! I have a thirst to change my stock audio but not sure what i can do. So I have a 6-disc changer that is stock, and I have a Motorola Droid Bionic. I want to know if there is something I can switch to that would mirror my display. I've seen the head units that can be...
  12. Kadori
    polk mm 15" s rubbish. looking for an upgrade! or A noob says Hello!
    Hello there! im kadori, im new here, only been doing this car audio stuff about a year and a half and well.. it shows so if you would help me out i would much appreciate it! Right so 2 weeks ago i got some brand new Polk audio 15" s poped em in a sealed box and i am severely disappointed in...
  13. J
    need help
    i need general info about subs they say db drive speed series sp10.1 but the pic i find wen i Google it isn't my speakers(have 3 tens) and the specs dont seem to match i had the 3 subs bridged to a 1600 watt amp (xterminator 1600.2) and sounded great but the amps ground wire burnt.and now i have...
