Fuse size
Lol you had to link the worst org for SQ. But no if you understood what it said you would know you're wrong
I looked i don't seen any meca events here. I agree usaci *****. Port was and door open in the kick scores.
Fact remains the way they "score" the actual over all sq is you basic frequency response. Noise, imagining, dynamics, clarity/detail "they use the term realism.hight,width, depth etc..
The older score sheets would say how realistic does it sound and it was worth 10 points.
I say resolution because the term means how realistic does it sound. From the tone to the attack/decay (transient response is the correct term and has to do with damping) clarity detail and the texture of the tone and tonality . Where in if the driver if under damped it tends to sound "flat" or blowed" with a slight delay in decay. While over damped it sound hollow and sharp so to say.
Everyone has slightly different terms. I use resolution to describe the exact reproduction.
Ive played alot of horns and heard a good deal of woodwind brass and drums so thats where im strong at critical listening.
Not to mentions everyone has a different sensitivity in the passband. Some people can't heard 19khz but can hear in great detail drom 10khz to 18khz.
Yeah. 10 grand he can't pass a AB test with his amp of choice vs lower budget ones.
Stop lying dude. Pick an amp out of ten not likely.
Im talking drect t drop in no processing on hifi loudspeakers.
The test he proposed is irrelevant and useless.
There is s point in which amplifiers measure beyond human precption given the same circurty and parts on two different amps will sound nearly identical and would be nearly impossible to pick out. After you get a slew rate sn etc etc high enought you wont hear it.
The point is cheaper shittly designed amps dont bench well and its audible.
在为高功率汽车音响系统选择保险丝时,很容易陷入选择困难症——很高兴这个帖子详细解释了线径限制和功放推荐,帮助大家避免代价高昂的错误。你甚至可以使用shotbg保存讨论中的关键帖子或图表,以便日后快速查阅。
When choosing fuses for high-power car audio systems, it's easy to get overwhelmed by the options – thankfully, this post provides a detailed explanation of wire gauge limitations and amplifier recommendations, helping you avoid costly mistakes. You can even use Shotbg to save key posts or diagrams from the discussion for quick reference later.
Translated.
psylo535
psylo535
tampa,fl.
