Fuse size
kmsl. no i didn't get offered and no i'm not driving. not to mention he never even state what kind of test he was going to do. i don't have to drive 1200 miles to do what I've done for 15 years.i find it ******* hilarious that these *** clowns who claim that they all sound the same have high dollar amps..
https://www.sonicelectronix.com/item_98471_Planet-Audio-PSA4CB.html
If it doesn't create noise it will sound just like a $10,000 amp set at the same real power it does.
Dude offered you $10,000 if you picked your amp out of 10. I'm sure someone as good as you would do that easily.
If it doesn't create noise it will sound just like a $10,000 amp set at the same real power it does. Dude offered you $10,000 if you picked your amp out of 10. I'm sure someone as good as you would do that easily.
picking an amp and doing a swap to see if in fact amps sound different are two different things *******..
Claims to be an electrician....100k+ more/yr. which I fail to see., Lives in an apartment, no audio to show for, no builds to date, etc. I don't believe it for one second.
highend amps have an audible difference? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
---------- Post added at 08:12 PM ---------- Previous post was at 08:12 PM ----------
If they sound different then you would know what yours sounds like??? I mean does one amp make Adele sound like prince?
wire is sized by circular mill. not car audio standards. period I use UL approved wire. fyi circular mil on strand count is different. soild wire carries the more current per volume. hte higher strand count is larger in diameter because it carries less current. just becasue it has more strands and is bigger doesn't mean it carries more current. its for flexibility
That is exactly my point
You can't use the ul chart because car audio wire is not. It is a great reference and starting point.
A good rule of thumb for decent quality car audio brand wire is 300A per 1/0awg run
That is exactly my pointYou can't use the ul chart because car audio wire is not. It is a great reference and starting point.
if that is the case it should be rater LOWER not HIGHER than he best cable money can buy.
You keep posting the same pics....which you've had for years now.
How about something new, mr electrician?
how about **** you. it sounds great.. lol subs in the tweeters are the only thing from time to time i move to toy with.
the sub and box is hard to get in the car it takes two people to pull it out the sub is around 88 pounds. im not going **** with a 160 pounds to prove anything to anyone who is as stupid as you and tool..
Wishing well sounds like **** on that video. Or maybe my phone speakers sound like ****. Because that's what I'm hearing.
Can you judge imaging, staging(width, depth, height) , tonality, spectral balance, ambiance, dynamics from a recorded YouTube video?
Or do you even know what that stuff is?
Post all your alibaba specials on diyma. I'm sure they will start thinking you are not a idiot. Give me a example of how you judge resolution.
judge? dude your talking to someone who was in band since 8 or 9. played a variety of instruments and in plenty of shows and marched. realism is one form. i can hear the difference between an instrument being flat or sharp, well i used to its been a while. i have friends that where in bands and that play and get wasted on a regular.
psylo535
psylo535
tampa,fl.
