Fuse size
Fuses are lame. Run straight wire.. and no boomin u don't want dual 175amp fuses. That amp would pop those most likely.
Dual input fusing is not an addition game. Example is if the manufacturer recommends 350amp fusing, then fuse both runs for 350a. Each wire is more than likely not going to see equal amperage draw. One wire may draw 200a while the other draws 150a and that's if you somehow reach the full amperage draw that amp can support.
If it's real 1/0 that's 300 amps. If it's aluminum it's 250 amps. I feel someone with this equipment shouldn't have to ask this question
And just because I own the equipment I should've know this ? Seems to be more than one different answer ,but I think I will run 350 amp fuses
psylo535
psylo535
tampa,fl.
