Speakers and subs not working help
Pookster
I installed 2 12s and an amp in my 1998 ford ranger, everything is soldered and hooked up, tested power and ground they are good and the amp turns on but subs make no noise. As I'm trying to figure this out standing outside the truck while I had music playing the music stopped out of nowhere. My head unit is a JVC KW-M788BH I installed a couple months ago in replacement of a cheap amazon radio i bought that was junk after like a month, the JVC still works and screen is like nothing happened everything works but no sound.
that was yesterday today i went out to the truck, the radio worked for like 20 seconds playing a random radio station and then it stopped and made a clicking sound like 5 times it kind of sounded like a NRG quick release lol. I was running the battery for maybe 10 minutes total but like on off for maybe half an hour and all of a sudden the battery died. so something is obviously not right here, I disconnected the battery and have it on the charger right now.
everything that is installed is all soldered and hooked up like it should be working fine but is not
When your battery runs low while playing music, the radio will make odd sounds. Charge the battery and when installed, play the music with the charger going at the same time. See if your radio issues continue while you have a good power source.
Sorry I couldn’t remember my login after testing it ended up being a bad alternator. Put a new one in today and subs are bumping idk how to delete the po
got it fixed today needed a new alternator thank you though
How many speakers to this Ford Truck Ranger? 4. I think I know the problem. Did you use 2 amplifiers or 1 amplifiers to the Ford Truck? If you used 2, then that means all 4 speakers should be working and the subs you bought. If you use only 1 amplifier to your truck then that means you're using the 2 for front fills and the subs. But you'll need a low-pass filter or crossover for the sub to make it work. 80 hz to 120 hz about going to the subs. The rest of your 2 front fills receive mid-range frequencies. It didn't work, because the subs should only receive lower frequency to make it work. On the amplifier if you only used 1 amplifier I'm assuming so, the tuning frequency should be between those two, 80 hz and 120 hz to work. Loud music. Did you come close to with these specs or limits?
Pookster
Pookster
america
