Video Request: 2 18's in a sealed enclosure
I don't believe anything in the DC lineup is really fit for running sealed alignment.
IF you're just looking to cram as much cone area into as small airspace as possible you can brute force reasonably loud with pretty much anything. Do what you like.
DC does give a a sealed box recommendation for Lvl 4 and down, I haven't modeled it yet however. I'm not necessarily married to DC either. Yes your description does word it best, I am looking to brute force as much cone area as I can without a wall. I'm still experimenting to see if I can stuff 2 15's ported as well.
You should be able to go to You Tube and the like to view quite a few Vids on 18" subs???? Stepping up would be ideal for a single sub game changer??
Sealed seems to be a rarity for what I'm asking, understandably. Not many people play the 18" game when tight on space. I may also play with the idea of a single ported 18" as well.
Hello, I'm getting back into car audio after a hiatus. I'm looking to do a build in my MK5 Jetta. An idea I'm toying with is 2 18's sealed in the trunk. I should be able to just squeeze in enough space for subs forward. This idea originally started as 2 18" in an IB set up but being a basshead at heart I'm worried the IB set up won't live up to what I want.
I know the simple answer is a set of 12's in 3-4 cu ft between 32-35hz, but I'd like to step outside of the box a little bit. Im just short on room to fit 2 15's and a 8" aero port facing subs forward/port forward, so this is my last ditch effort to make large cone subs work in my application.
Hoping to see some videos of 2 18"s sealed or 2 15"s sealed. Suv, truck, hatch, trunk, I'd like to see them all! Thanks in advance.
I'm a bass head through and through. I have a MK4 jetta with a single 18 I currently. In the works is a new baffle to run a pair of 18's IB while I sort out finances and can finish the final enclosure for the back seat area.
With the proper drivers, infinite baffle will be plenty of output. If you really enjoy the "peak" around 35hz that alot of ported boxes have, then you may feel like you are missing something. But infinite baffle and sealed are virtually the same type of enclosure. Airspace is the big difference. Not many 18's perform super well in less than 2 cubes, and the ones that do are usually rather pricey.
Matt
Geeze, 2 18’s in a Jetta trunk? That’s like Ron Jeremy in a 16 year old, probably not gonna to fit!
Lol, comments like that are the reason my jetta no longer has back seats and looks like this:
It will fit, you just have to make a little room here and there...
Matt
Matt
I think I can make about 7cu ft work in the MK5, I have to make a cardboard mock up to see if it will slide in or if it would have to be built in trunk.
I built two subs using this Peerless subwoofer, home theater job. Dual 15's in each of the two 5.5 cubic foot, ported enclosures, I want to say three 6” diameter ports by 5’ long due to potential vent velocity issues, f3 around 21Hz?. Powered them with a PAIR of 2000 watt crown amps, simply took your breath away, really impressive.. I'm still toying with the idea of running 2 of them in a 4ft sealed box. Now 3 of them in a 6 cubic ft sealed box (1.3 ohm load) wow! Never done an IB setup. Would think that pre drivers would be suited for that, could be wrong. I think they're around $4-$450 each, not supoer expensive for what they are.
Depending on the driver and how much power you have available 7 cubes could work fine. My enclosure will be about 14 cubes after displacements, but my subs are really weird and I'm going for a very low-end oriented substage.
Matt
OneBigHoe
OneBigHoe
Wisconsin
