What Wattage is too expensive?
That's the thing I need to read up on. 6s could handle my charge voltage (>= 15V for a long time after cranking) but I am always worried I'll be too close to the minimum charge for the cells. Clearly you aren't having problems.
I still don't know exactly whats going on. I know bursts like starting cars and such require alot of current, but not much overall power. With my 14.4v I'm probably only getting 60ah of capacity from my bank or so? Someone did the math on here. I don't believe there is really a minimum charge. LTO is a bit weird. It will run down to 1.5vish per cell or 9v for a 6s, and that's pretty much empty. But from what I've read they are happy anywhere from 1.7v-2.7v. Still reading about all the little details.
Matt
Matt
Deff something Id like to read up and learn about. Im going to need to find out what and how many I will need to run at least 8-10k on substage and approx. 2-3 on front stage, with enough to keep my truck happy with my 3oo amp alt or 255. I have both Alts already. I plan on putting my GP 300 amp alt. in this summer
That's about double what I'm running, so I'd guess 160-200ah of yinlong.
Matt
Maybe you misspoke: You can't have relatively high current at any given voltage and not have relatively high power. Cranking is the highest load most batteries encounter, which is why batteries are rated in cranking amps, and also why it drains your battery so fast.
My Sub dealer said my Sub probably only uses 1000 Watts.
So would a 130 Amp Work?
Also could a 130 Amp be used for a second Battey if 1000 Watts is all that's necessary?
Think I'm only using 12 Amps constantly with my Sub.
10Amps for the Car?
130 Amp Alternator would be enough for the 2 Capacitor, Battery?
10Amps for the Car?
If you're only using 1k on your sub 130 amp alt is fine. If you see yourself going up at some point in the future, may as upgrade now.
You are right of course. I think he's just observing that batteries have low average power relative to their output while cranking (like how their AH rating is tiny compared to their CCA).
Can I still use the Capacitor and 2nd Battery with the 130 Amp?
Thanks!
You can. If one battery is a lot older than the other or a different make use an isolator. It's basically a giant relay (switch). Stinger makes one that'll take 500 amps. It's important not let one die though. A digital voltmeter is advised.
I was about the first person in the USA to get into LTO cells. At the time we did this the only other people who were using those for car audio was a team in Russia.
So far so good, these are still performing admirably. I did a lot of research on this because none of the car audio "brands" would give me straight answers but only sales pitches.
Currently I do have some YingLong 40AH cells and some Toshiba 10AH cells. I do not think anybody is doing ready made banks for the Toshiba cells but YingLong 40 has become very popular so off-the-shelf options for busing are easy to come by. Without a well kitted out metal shop you'll definitely struggle building your own bus bars. I did a 5s bank of Toshiba last summer for my 4 wheeler using just 8 gauge wire and some ring terminals and that works the balls; I still haven't got around to building a car audio sized bank of those, small terminals make it a bit intimidating and IMO definitely limits you to copper if you don't have a very good machine shop to counter-sink aluminum thick enough to carry big currents. Really I think for a powersport battery 5s Toshiba will be impossible to beat in price and longevity, those fill with liquid ones are 90-100$ and barely last a year, parts store lithium for those are over 200$ and I got about 3 years out of the one I auditioned.
Anyway, the only thing I'd take exception to that has been posted here is claims of charging 6s banks up over 15.5V. The Russian dudes and my source in China did not suggest this and I can say charging at normal car voltage (14.4-14.8) seems to provide ample performance for those of us doing so.
Yes, you are correct. Power is volts times amps. But 12v X 300a for 5 seconds is less than 12v X 100a for 30 minutes. My point was simply a simple 5 second jump isn't the same power as 30m of my system at decent volume. Yes, starting is alot of current, but part of that is due to battery resistance and wire loses causing voltage drop. Lower voltage means more amps for the same power output.
I'd love to get some kind of meter and find out how much power my jetta takes to turn over, I highly doubt it's anywhere close to the "950cca) the factory battery was rated for. When starting my car now, my voltage doesn't even drop from the resting 14.3 or so.
Matt
Edit: also, lithium batteries are MUCH better suited to heavy load situations. Most AGM or lead-acid batteries only support 50 percent depth of discharge. That means your 40ah battery is only good for 20ah in real world use. Lithium are generally good for upwards of 80 percent, and they maintain their voltage in a much flatter discharge curve. Lithium is all aroind just better.
what ^ said. amp gain setting info, test tones are at the very bottom...
408
Which amp and which speakers? What crossover are you using? You may be fine so long as you never push the volume too hard.
DJ subs are designed for efficiency, car audio subs are designed for low end in a small space. So above ~50hz the DJ sub will kill a car audio...
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
Jake321
Jake321
Hawaii
hispls
    May 16, 2024
    May 16, 2024
