Can Someone Model Some Subs for Me?
My current box is only 3.69 cubes net not 4.4.
Well i think you will be more that 3 db down at 30hz then but that doesn't mean you won't get decently loud at 30hz your adding another sub and hopefully adequate power between the 4. I think you'll find that you will have a box that will be 32-45hz peaky but then again you might not even notice how peaky it is without a meter to read it. 6db of peak is alot but to the ear it's not that much.
If it's just a mounting panel swap I see no reason to not try the 3.7cube box.
What do you mean adding another sub? I'm just switching out 4 - 8's for 4 - 10's.
Similar situation more cone area more air displacement
For some reason I thought you were going from 3 10s to 4 tens.
4 8s to 4 10s is even more dramatic of a cone area change. 113in² of cone area difference the equivalent of 2 more 8s.
Correct. 57% more cone area. I would like to be a little windier and pick up a db or two.
You should be able to do both. Your lower frequency limit might be a few hertz higher and you might need more power to maintain the current lower frequency db
But if you lose a few db at 25 hz and can still play 28hz due to cabin gain. You may very well grab a few db at peak. It'll definitely be windier. Though I don't really see 4 tens as alot of cone area. It's more than I've run in recent years. Lol
Me I'm gonna go from 2 10s to 4 6.5s so I can drop my rear seats back to factory height. I had 2 6.5s at 1 point that were decent so 4 bigger 6.5s on more power should be fine.
That cone area is fairly close in your setup. Good luck.
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
Bobbytwonames
